SKYWORTH DVD-810 [ES4408]
VIDEO-DVD - EPROM
510.5 KB
EPROM
Looking for similar skyworth manual?
    SKYWORTH DVD-810 DVD810 [ES4408] DVD 810 [ES 4408
Thomson VTH-6400E SAFE kinyitása. Megoldva!
Sziasztok! Tudja valaki, hogy a fenti videó SAFE üzemmódját hogyan lehet kinyitni? A tulaj szerint a táv piros gombjával lehetett (esküszik rá), de most azzal nem megy. Köszönettel Attila
Sony Sl-S770 vcr interrupted playback and AV display issues
I'm encountering an issue with my Super Betamax player. During playback, some cassettes abruptly stop playing at seemingly random points, accompanied by a sound similar to the one made when a tape reaches its end. This interruption also renders the rewind and forward buttons unresponsive. However, it does not impede the manual forwarding or rewinding of the cassette. The only solution seems to be ejecting the cassette and reinserting it. Occasionally, even this workaround fails, allowing only two seconds of playback before the problem recurs.
I sought guidance from the Mister Betamax troubleshooting page, which indicated that the tape safety device might be the root cause. I received additional advice suggesting that the issue could stem from one of the sensors within the VCR, possibly due to oxidized contacts causing intermittent operation. It was recommended to resolve this by carefully cleaning the contacts on the sensor switch responsible for detecting loaded tapes or the sensor that detects if the tape is "record-protected." Another suggestion was to monitor the output of these switches using an oscilloscope or voltmeter to determine if they are indeed the source of the problem.
I'm eager to hear if anyone has additional advice or personal experiences to share regarding this issue.
Additionally, I'm facing an AV cable problem where the yellow AV cable fails to display any video. While it used to work correctly, the AV audio cable still functions properly. As a temporary workaround, I've been using a coaxial cable and routing it through another VCR to utilize its AV output. However, I'm interested in exploring potential solutions to fix the issue with the yellow AV cable, if possible. Any insights or suggestions would be greatly appreciated.
AIWA HV-FX3800 VHS videó felvevő több éves pihenő után a kazetta fészket nem emeli ki.
Tisztelt Szakik! Segítséget szeretnék kérni Tőletek a témában említett videó felvevő javításához. Sok éve pihenő videófelvevő készülékkel a családi felvételek digitalizására szántam el magam, de mindjárt az elején probléma adódott a szalag befűzés után a lejátszás nem indult, a kazettafészek félúton leállt. Szétszedtem, az idler görgőt meghajtó szíjat cseréltem, de úgy tűnik ennyivel nem úszom meg, a görgőt is cserélnem kellene, de nem találtam a neten a készülék alkatrész listáját, illetve azt sem tudom, hol lehet még alkatrészt szerezni, rendelni az ilyen öreg masinákhoz. A segítségeteket előre is köszönöm. Üdvözlettel: Sándor
AIWA HV-DK510 felcsévélés gyenge
Tisztelt Kollégák! Van nálam javításon egy Aiwa HV-DK510 típusú video, aminek a mechanikája nem egészen úgy működik, mit kellene. Komplett szíjcsere után vagyok, lejátszáskor a felcsévélő orsó nem tudja húzni a szalagot. A kuplungot megnéztem az elvileg rendben van. Mechanikai rajzot nem találtam sehol a neten, valaki tudna ebben segíteni, hogy küldene egyet, vagy egy elérhetőséget, hogy hol találok? Köszönöm előre is! Üdv.
